Hi
we are looking a simple cost effective buck converter
Input DC Is +55VDC
output DC is 35VDC, load current at 35VDC is 3A.
can you suggest a cost effective simple solution.
rgds
yogesh singhal
Hi Yogeshks1:
Is this OK for your reference? This is high performance Class-D OPAMP loop.
-B change to ground, speaker change to your load and connect to ground.
Remove input cap, it can change to high voltage input high power buck DCDC.
This is IR4301M for your reference:https://www.infineon.com/cms/en/product/power/class-d-audio-amplifier-ic/integrated-class-d-audio-am...
Hello @yogeshks1 ,
Thank you for posting your query on Infineon Community.
To propose an optimum solution to you, can you please share the following details,
- Application
- Are you looking for an integrated FET solution or are you open to choosing external FET solutions also.
Premsagar S
Hi Yogeshks1:
