automate PowIRCener software to program MIC files
Kush1490
5 replies posted 5 questions asked 10 sign-ins
Could you please advise if there are any recommended ways to automate PowIRCener software to program MIC files. Is there any command line interface available to it?
Nishanth
100 solutions authored 10 likes given 100 replies posted
Hello @Kush1490 ,
Yes, Gang programmer can be used to do the programming.
The parts needs to be programmed separately in Gang programmer and then mounted on the target board.
Are you using IRPS5401 part to do the programming?
Nishanth
Nishanth
Hello @Kush1490 ,
Thank you for contributing to the Infineon Community.
There is no command line interface available for PowerIRCenter GUI.
We will check further on this.
Nishanth
Kush1490
can  Engineer  use Gang Programmer board and then perform the programming ?
Nishanth
Hello @Kush1490 ,
Nishanth
