- Email to a Friend
Can XDPP1100 digital power controller can be used for building 6000W-200A or 9000W-300A power supplies.
- Email to a Friend
Hello @navsuh ,
XDPP1100 is typically designed for medium voltage DC-DC applications.
With this IC, Vin is limited to 127V, Iout maximum to 127A per phase, and 255A maximum Iout with interleaved PSFB.
To support higher input voltage or higher output current, a Firmware patch is required to scale the resolution and range.
Please refer to the below link for the reference design of an evaluation board (which uses this Firmware patch), designed to support Vin till 400V.
https://www.infineon.com/cms/en/product/evaluation-boards/vd_1000w_gan_psfb_xdp/
Premsagar S
- Email to a Friend
Hello @navsuh ,
Thank you for posting your query on Infineon Community.
Can you please provide the following details of your design,
- Voltage ratings of Input & Output.
- Current ratings of Input & Output.
- Application.
- Selected power stage topology & switching frequency.
Premsagar S
- Email to a Friend
Hello Premsagar S ,
- Voltage ratings of Input & Output are 540V DC, 30V-50V DC.
- Current ratings of Input & Output 20A-30A, 200A-300A.
- Application-welding and cutting.
- Selected power stage topology & switching frequency are Full bridge or half bridge,100KHZ-200KHZ,current mode/PCMC.
- Email to a Friend
Hello @navsuh ,
Premsagar S
