TeMa_2997106
Level 6
Level 6
Distributor - TED (Japan)
10 likes received 10 solutions authored 250 replies posted
Is it possible to set the polarity of the WK pin on the TLE9461ES to HIGH active instead of LOW active?
If it is yes, which register should I set?
Tetsuo
Albab_A
5 likes given 50 solutions authored 100 replies posted
Hello Tetsuo-san,
As discussed, The wake input pin it is edge-sensitive and has a switching threshold of typically 3V.
Both transitions, High to Low and Low to High, result in a signalization by the SBC. The signalization occurs either by triggering the interrupt in SBC Normal Mode and SBC Stop Mode or by a wake-up of the device in SBC Sleep and SBC Failsafe Mode.
Albab
Albab_A
Hello Tetsuo-san,
Are you talking about why we have High Input pin as WK/VSENSE? It is described in datasheet  under section 5.4.1
Additionally, WK voltage capability is 40 V (AMR) and in addition with the protection circuitry as depicted under "Application Diagram", you can use it without the transistor.
Let me know if you need further assistance.
Albab
TeMa_2997106
Level 6
Level 6
Albab-san,
Since WK is LOW active, the IG voltage was logically inverted using a transistor and input to WK. I thought that if it could input IG directly, it could reduce the number of parts.
Tetsuo
Albab_A
Hello Tetsuo-san,
Albab
TeMa_2997106
Level 6
Level 6
Albab-san,
Thank you very much.
I understand.
Tetsuo
