jh2
First reply posted First question asked First like given
Voltage trackers that I see in Infineon portfolio (for example TLS115B0EJ) are down to 2V (ADJ/OUT).  In my setup LDO input will be 5V, output current under 150mA, and ADJ/OUT should go down to 1.7V. Is it possible for this devices (specified with min 2V ADJ/OUT) to work fine in my setup?
Thank you
J.H.
Abhilash_P
50 likes received 500 replies posted 250 solutions authored
   For your application, please use TLE4252.
TLE4252 has ADJ voltage down to 1.5V.
Attached the datasheet for your reference.
Abhilash P
Abhilash_P
Abhilash P
jh2
I am looking for something like this but in smaller package.
J.H.
Abhilash_P
   Following are the IC and the packages that are available,
Abhilash P
