I use stm32G431RBT6 to communicate with the tle82453 by spi.
For tle82453:
The clock is from extern 25Mhz accurate clocks. The divider is 6.The spi is slave,with spi clk from the stm32G431.The MOSI and MISO are connected to stm32G431 too.
For stm32G431RBT6:
When I configure the spi clock with 25Mhz,and divider of 16.The communication is normal without error.
But when I configure the spi clock with other values,e.g,21.25Mhz(The max frequency of stm32G431RBT6 170 Mhz divided by 8 ),and divider of 16.The communication will fail in debug.
I wonder whther the clock frequncy and the spi frequncy of tle82453 are limited in some cases.I would be appreciate for your
Yes indeed, the Functional Range of the SPI Clock Frequency is limited @ max 8MHz. To ensure correct functioning, please use parameters within specified limits.
Pranava
Pranava
