Hello
I am trying to established a connection between TC399 and TLF35584 using QSPI0.
I am using Infineon MCAL ( AUTOSAR ) and configured SPI module with below values.
- Communication mode is set to synchronous.
- Baudrate at 50MHz
I am using example code given by infineon. The sequence I am following is as below.
Spi_Init () : This function is initializing the configured channels ( Currently only one for TLF )
initTLF35584() : This follows the sequence of
unlockRegisterTLF35584();
disableWindowWatchdogTLF35584(tlfDevice);
disableErrPinMonitorTLF35584(tlfDevice);
Then calling getCurrentStateTLF35584() to read Device Status. I am getting 0xFF which does not look like right value. I am expecting a value indicating device is in INIT state.
Power Management
- tlf35584
Can you please share the oscilloscope trace for this? I will check that and let you know. At your end can you please try adding a delay between Init() and getCurrentState() and check if you are able to get a proper response?
Pranava
Pranava
Hi @Pranava_YN , Thanks for response.
ANS 1 : At this moment oscilloscope trace is not available. Its actual ECU on which I am figuring out testpoint to capture trace on oscilloscope.
ANS 2 : As per suggestion I added delay but the result was same.
With some modification in SPI configuration , the value which I am getting now is 0xFF7F when I am disabling the watchdog and Error PIN.
Q 3 : Can some one confirm me the configuration for SPI done using EBTresos as below is right ?
> General Configuration
SpiChannelBuffersAllowed : 0 ( IB )
SpiEnableLoopBackApi : 0
SpiLevelDelivered : 0
SpiSupportConcurrentSyncTransmit : 1
SpiSyncTransmitTimeoutDuration : 0xFFFF
SpiHwStatusApi :0
SpiInterruptibleSequence : Disable
> Channel Configuration
SpiChannelId : 0
SpiChannelType : IB ( Internal Buffer Type )
SpiDataWidth : 15
SpiIbNBuffers : 10
SpiTransferStart : MSB
> Device Configuration
SpiBaudrate : 5000000
SpiCsIdentifier : Channel 0
SpiCsPolarity : LOW
SpiDataShiftEdge : TRAILING
SpiEnableCs : 1
SpiHwUnit : QSPI0
SpiAutoCalcBaudParams : 1
SpiShiftClockIdleLevel : LOW
SpiParitySupport : EVEN
SpiCsSelection : CS_VIA_PERIPHERAL_ENGINE
SpiDelayParamTrailPre : 2
SpiDelayParamTrailLength : 5
SpiDelayParamIdlePre : 0
SpiDelayParamIdleLength : 1
SpiDelayParamLeadPre : 0
SpiDelayParamLeadLength : 7
> PORT Configuration
General
PortNumber 22
PortNumberOfPortPins 12
PortPin4
PortPinDirection PORT_PIN_OUT
PortPinInitialMode ALT4
PortPinLevelValue PORT_PIN_LEVEL_HIGH
PortPinOutputPadDriveStrength PORT_PIN_DEFAULT_DRIVER
PortPinOutputPinDriveMode PORT_PIN_OUT_PUSHPULL
PortPinMode PortPinMode PORT_PIN_MODE_ALL
PortPin_5
PortPin_6
PortPinDirection PORT_PIN_IN
PortPinInputPullResistor PORT_PIN_IN_PULL_DOWN
PortPinInputPadLevel PORT_INPUT_LEVEL_CMOS_AUTOMOTIVE
PortPin_7
PortPinLevelValue PORT_PIN_LEVEL_LOW
Q 4 : Interrupts for SPI are disabled. SPI Autosar module provides read and write API which are used. Interrupts are not mandatory is my understanding. Is it right ?
Sorry for the delay in responding,
Yes, both SPI configuration and your understanding on SPI interrupts are correct.
Pranava
