Hi experts,
After the first single interrupt or safe state related comparator on the full path and test, IF.ABIST and IF.MON bit are both set. However, ABIST_CTRL0.STATUS = 5, ABIST_SELECTx = 0 and the corresponding bit in the MONSFx register is set , which seems right.
What is the reason for this?
- sbc
Hi AliAl,
I found that the reason for the IF.MON is always set was due to the grounding of the STU, which resulted in a persistent Preg UV fault.
Thanks for the query. In order to provide detailed solution, can you please describe the status for MONSFx and values after reading the bits to check which bit is set .
Albab
Hi AliAl,
Thanks for your reply. I tested VBAT_OV, and MONSF3 is 0x01h.
After I block the conditions in the red box in the following figure, all ABIST can pass.
Hi AliAl,
