Zeke
First question asked First like given Welcome!
Datasheet does not mention anything about the need of Pull-up resistors for LIN_TXD and/or LIN_RXD.
Are these needed?
AnilKumar
First question asked 50 solutions authored 10 likes received
Please refer Figure 32 of the datasheet TLE9262BQXV33XUMA1 (Also attached below)
Block diagram in the figure clearly shows a pull up resistor for TXDLIN and Push-pull configuration for RXDLIN.
Hence, external pull ups are not required as they are considered internally.
Moreover, the value of Pull Up resistor for TXDLIN is mentioned in Table 19 Electrical Characteristics (See below)
Anil
AnilKumar
Anil
AnilKumar
I hope your query is resolved. Reach out to us if you need any further assistance.
Anil
