aravindrnair
First like given 5 sign-ins First question asked
I am using TLE92464ED for driving solenoid valves. I am able to read the Version id through SPI,but after that whatever I right the reply on MISO line is 8504000. I have tried to disable CRC and is not happening. I couldnt find the steps to initialize the IC properly in the datasheet. Is there any sample code available. Please help me to understand how to properly initialize and drive the valves
herringbur
5 replies posted 5 sign-ins First like received
This does not look to be the correct solution. I would probably make sure you are sending the correct command first. CRC is enabled by default, so I imagine your first message has to be one that includes CRC.
