Translation_Bot
When used by any command using SPI, the data read is 0x8500. Why is this?
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/%E7%94%B5%E6%BA%90%E7%AE%A1%E7%90%86%E8%8A%AF%E7%89%87/TLE92464-SPI/td-p/664667
Translation_Bot
Hi millionaire,
Refer to datasheet:
0x8500 means no error if you are in reset state
Please check if you are in reset state according to datasheet 20.
Xiangrui
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/%E7%94%B5%E6%BA%90%E7%AE%A1%E7%90%86%E8%8A%AF%E7%89%87/TLE92464-SPI/m-p/664772
Translation_Bot
Hi millionaire,
Refer to datasheet:
Xiangrui
Translation_Bot
Thank you very much for your reply
The problem with SPI has been resolved
I have another problem now: I can output the current problem, but I want to read the current value, and the value I read is always zero, which is why?
I look forward to your reply.
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/%E7%94%B5%E6%BA%90%E7%AE%A1%E7%90%86%E8%8A%AF%E7%89%87/TLE92464-SPI/m-p/666571
Translation_Bot
Hi Fuhao,
Thanks for the question.
But it's better to create a new discussion for current sensing.
And please check and provide your schematic (refer to figure 21) and current discussion steps, i.e. input and output SPI commands (refer to figure 22) in new discussion, if needed.
Xiangrui
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/%E7%94%B5%E6%BA%90%E7%AE%A1%E7%90%86%E8%8A%AF%E7%89%87/TLE92464-SPI/m-p/666763
