- Email to a Friend
Hi!
I am not willing to use the Reset function of the TLE4267 IC. Kindly tell me where I should connect the regulator's Reset Delay (D) pin if I am not willing to add a capacitor.
- Email to a Friend
Thank you for posting your query in Infineon's community.
You can keep the RO and D pin open if you are not using reset functionality because internally the reset is still on. Reset generator is connected with a pull up to Vq. So, it is not a problem to keep the pins open.
Reach out to us for any further query.
Anil
- Email to a Friend
Hello dear member!
Please help me to find the answer.
- Email to a Friend
Anil
