I am using TLE9471ES SBC. I want to know that if i short MISO and MOSI what would be the result/reaction.
And whether SBC will detect any kind of fault like communication error due to this.
will it possible to keep communication between SBC and other device even if the MISO-MOSI Short occured.
Thanks in advance
Thanks for posting your Query in Infineon community.
Shorting pins MOSI,MISO is same as loop back of MOSI to MISO. That means, Any message sent from master via MOSI will be read back to MISO irrespective of slave device.
Let me know if you have further questions
Anil
Anil
