S6SAE101A00SA1002 Solar-Powered IoT Device Kit queries
Hi there. I would like to ask for the S6SAE101A00SA1002 Solar-Powered IoT Device Kit is there anyway I could monitor the output of the solar cell, the remaining battery charge and the power consumption by the internal hardware on the EH motherboard?
Yuva
250 replies posted 250 sign-ins 100 solutions authored
You may refer to the code example project ' CE215119_BLE_Battery_Level' available for the PSoC 4 BLE device which measures the battery voltage. The kit has provision to measure the current consumption using multi-meter, you have to use trans-impedance amplifier, etc if you want to measure the current in firmware. You can refer the kit guide in the following link.
http://www.cypress.com/file/187321/download
Yuva.
Yuva
Yuva.
