Ashbin
5 questions asked 5 sign-ins Welcome!
We use IR38363 in our design.
Can someone let me know if the part mandatorily requires configuration through PMBUS/I2C Dongles?
Will the component work without any I2C commands by default just by using external discrete?
Ashbin
Nishanth
100 solutions authored 10 likes given 100 replies posted
Hello @Ashbin ,
Thank you for contributing to the Infineon Community.
IR38363 part comes with a default configuration set in SVID mode.
If your application requirement is the same as the default configuration then no change will be required.
If your application requirement is different then you will have to use SVID/PMBUS/I2C communication to make the changes.
Nishanth
Nishanth
Hello @Ashbin ,
Nishanth
