nsyed
50 sign-ins First solution authored 25 sign-ins
TLF35584 data sheet indicates "In case of over voltage at pin QTx, the corresponding tracker will be switched off, the event will be stored in an SPI status register (MONSF1) and an interrupt will be generated."
When the over voltage event ends, how/when does the tracker turns back on ?
- does tracker self recovers and turns on or
- does clearing the status register MONSF1 recovers the tracker ?
MoD
5 likes given 250 sign-ins 25 likes received
I don't know at which forum are the PMIC experts.
The answer to your question you can find in the datasheet page 72/73, especially Figure 22.
If an overvoltage is detected for a time period of 8µs..20µs (tRR . reset reaction time) then the affected regulator is switched off and must be reenabled by the microcontroller.
If an undervoltage is detected for a time period of 2.7ms..3,3ms (tStG - Short to ground detection time) then the affected regulator is switched off and must be reenabled by the microcontroller.
I expect in case of detected overvoltage that you can see in register DEVSTAT that the tracker is switched off and you must reenable the tracker via register DEVCTRL/DEVCTRLN (used to enable or disable a tracker by sw).
nsyed
Dear Community Members,
Any comments on this question ? Appreciate your help !!!
nsyed
Any feedback on this topic ???
nsyed
nsyed
Are there no TLF35584 experts in this forum ? Should I be posting this question in a different forum ?
nsyed
Where are all the Infineon community members. There is no support ???
MoD
