Power Management ICs Forum Discussions
nsyed
50 sign-ins First solution authored 25 sign-ins
TLF35584 data sheet indicates "In case of over voltage at pin QTx, the corresponding tracker will be switched off, the event will be stored in an SPI status register (MONSF1) and an interrupt will be generated."
When the over voltage event ends, how/when does the tracker turns back on ?
- does tracker self recovers and turns on or
- does clearing the status register MONSF1 recovers the tracker ?
