- Email to a Friend
Hello community! I am currently working on a project that includes TLF35584QVHS2 and since there is not an analytic datasheet for that model, I wanted to ask if it is safe to bridge the power supply outputs QT1(pin 33) and QT2(pin 32) so I can use the maximum current to supply some sensors.
- Email to a Friend
We can connect QT1 and QT2 together, But I recommend keeping 1Ohm resistance in series to have a better current share between the trackers. You can use the below diagram and excel sheet for the calculation of the load share. Please modify the loads and resistance values in excel according to your application.
You have any further question, please let me know.
Vishnu N
- Email to a Friend
Vishnu N
- Email to a Friend
Thanks a lot for the quick response! The thing is I want it to be versatile to different currents for different brands of sensors.
- Email to a Friend
You can consider the worst-case load while designing. Use the above approach to check the current share for each tracker in the worst case. Please make sure your operating points are within the datasheet limits.
Vishnu N
