Power Management ICs Forum Discussions
drudolf
First question asked Welcome!
I am powering an Intel Arria 10 FPGA and am using your power demo board design as a starting place: https://www.infineon.com/cms/en/product/promopages/Altera/
Is there a recommendation for a different IR MOSFET than the IR3555-IR3557 to use with the IR35204? These FETs are obsolete or unavailable.
Dan
SPCH
Moderator 50 sign-ins 5 solutions authored 25 sign-ins
Thanks for posting at Infineon Community.
We recommend you to go with the IR35204 Controller + TDA21472 Power stage.
Please note below points
1. TDA21472 and IR3555-IR3557 Footprints are not identical.
2. Functionally fine-tuning is necessary with TDA21472.
https://www.infineon.com/dgdl/Infineon-TDA21472-DataSheet-v02_00-EN.pdf?fileId=5546d4626cb27db2016d1...
SPCH.
