Hi everyone,
I need to use PowerCode software to debug Multiphase Digital Controllers. Then I get the activation code, and success activate. But the PowerCode software don't started, no window and nothing more. I check the Windows Event Viewer and find the Error in Application log.
Application: PC_50.exe
Framework Version: v4.0.30319
Discription: The process was terminated due to an unhandled exception.
Exception: System.DllNotFoundException
at <Module>.OpenUsbDeviceHID(Byte*)
at Primarion.PMBServer.PmbServer.ConnectUSB()
at Primarion.PMBServer.PmbServer.OpenPort()
at Primarion.PMBServer.PmbServer.get_DongleVer(UInt32 ByRef)
at Startup.MainDlg..ctor()
at Startup.Program.Main()
Hi @Jin0301 ,
Please raise a case in the Infineon Case Management portal to debug & resolve your issue with PowerCode GUI. Following is the link for the Infineon Case Management portal,
Please find the below images to raise a case,
Steven
Hi @Jin0301 ,
Steven
