Power dissipation in TLE9261-3BQX
dhereavi
5 sign-ins First reply posted First like received
Dears
I want to know.
1)Maximum power dissipation in TLE9261-3BQX?
2) To increase current capacity can we Short the Voltage regulator 1 & Voltage Regulator 2?
Albab_A
5 likes given 50 solutions authored 100 replies posted
Regarding the second part of your query, it is not recommended to short VCC1 and VCC2. It may act as a parallel path for current distribution and increase the current consumption but there are chances that internal circuitry may get affected resulting in unwanted outcome.
Albab
Albab_A
Thank you for reaching out to us. Unfortunately, we cannot share specific documents or information related to Infineon products on this platform as this data (max power dissipation) is mentioned in the PPAP document . For any technical support or documentation, we request you to please raise a case in the Infineon case management system. Our technical support team will assist you further with your query.
To raise a case, please visit the Infineon website and navigate to the "Support" section. From there, you can create a new support case and provide the necessary details related to your query. You can follow this link to create a case https://mycases.infineon.com/
Albab
Albab_A
Albab
