Power Management ICs Forum Discussions
Teoman
5 questions asked 10 replies posted 10 sign-ins
Hello everyone,
I have been looking for a method for performing Hard Reset on TLF35584/85. When I examine the datasheet and manual, it seems that only solution is to not trigger Long Open Window twice and making soft reset and hard reset respectively.
Nevertheless, I need a different method that no need to use WDG feature.
How can I implement hard reset in that situation??
Thank you very much for help.
AnilKumar
10 likes received 100 sign-ins 50 replies posted
Hard reset is when ROT Pin goes below ROT low threshold and the post regulator output voltages are switched off.
Another way to generate such a hard reset is to send the TLF from Normal state to Standby state.
Anil
AnilKumar
Anil
Thank you for the reply. Yes, you are right. I tried already and see that the method you stated is valid.
Thanks again!!
Teoman
