kumarluc
Distributor
5 questions asked 10 sign-ins First reply posted
Hi
I need CAN IC with SPI & 5V supply voltage. I have checked TLE9255W but it is having Vbat 5.5V minimum.
Please advise if we have any other option.
Lucky Kumar
Albab_A
5 likes given 50 solutions authored 100 replies posted
Hello Lucky,
Thanks for the query.
Do you want to 5V battery supply voltage (Vbat) or transmitter supply voltage (Vcc). Because TLE9255W does have a 5 V supply Vcc.
If you can check the application diagram here in the datasheet  you can notice that Vcc is coming out of the LDO output whose input is coming from Vbat. So Vcc=5 Volts is powering the Tx as an "independent" supply in addition to Vbat.
Albab
Albab_A
Hello Lucky,
Albab
Albab_A
Hello Lucky,
Please let me know if your query is resolved or you need further assistance?
Albab
