sbl
Level 4
Level 4
25 sign-ins 25 replies posted 10 sign-ins
Can we use NFC with WLC1115?
Samir
Kanahaiya_K
50 likes received 100 solutions authored 10 likes given
Hi @sbl
Sorry for the late response.
The Flash memory for WLC1115 is 128 kB and the coil MP-11 SDK needs the internal memory of 120kB.So,only 8 kB of memory is free for the use.
Please  Verify the memory size with NFC reader for communication purpose.
Kanahaiya
Kanahaiya_K
Hi @sbl
Thanks for posting on the Infineon Developer Community.
Yes, It is possible to use NFC with WLC1115 .But, It is necessary to consider the following points.
1.The IC supports NFC tag solutions, But you need to find reader from the other suppliers.
2.The flash memory of WLC1115 is 6-7k.Verify the memory size with NFC reader whether it is appropriate for communication  or not.
Kanahaiya
Hi Kanahaiya,
Tanks for your answer.
Can you please give me an example of NFC which is supported by WLC1115?
Samir
sbl
Level 4
Level 4
Can you please answer?
Kanahaiya_K
Hi @sbl
Unfortunately, we don't have any example .The NFC reader you are using must be taken into consideration while configuring NFC.
Kanahaiya
Hi Kanahaiya,
Can you please explain this point?
Samir
sbl
Level 4
Level 4
Kanahaiya_K
Hi @sbl
Kanahaiya
sbl
Level 4
Level 4
okay thnx!
