Hasan2021
Hi there,
I am willing to design similar product for diffirent input range,
Can you suggest any IC that is applicable for muilti output like 5V/3A, 12V/2A with 250-650VDC input?
Lets talk about https://www.infineon.com/dgdl/Infineon-ICE2QS02G-DS-v02_00-en.pdf?fileId=db3a30431a5c32f2011abef4f7f...
My applicable circuit should be following type. See the attachment.
Abhilash_P
25 likes received 250 replies posted 250 sign-ins
    The demo board DEMO_5ASAG_60W1 is a good match for your requirements.
Abhilash P
Abhilash_P
    Thankyou for Posting on Infineon Developer Community.
I understand that your are designing a Flyback converter with multiple output voltages.
As rightly pointed out by you, you can go through our portfolio of CooLSET ICs which is targeted for Flyback Controller applications.
The following are the available ICs in this portfolio,
QR Flyback Controller IC
Fixed frequency controller IC
For achieving ZVS, you can opt for the following controller IC,
https://www.infineon.com/cms/en/product/power/ac-dc-power-conversion/ac-dc-pwm-pfc-controller/advanc...
Unfortunately we donot have a complete circuit which has a flyback controller with multiport configuration.
But we do have POL ( point of load ) voltage regulators. Many POL can be connected on the output of a Flyback converter to achieve multi port output.
The portfolio of POL regulators can be found here
I suggest you to look at the following POL regulators that matches your application,
IR3883MTRPBF
IR38060M
Additional suggestion:
    If the converter in your application is not fixed, then you can go for our PFC+LLC combo controller IC.
These do have application notes that demonstrates multiport output voltages. Few application notes which matches with your specifications are as follows,
1) Using IDP2303
2) Using IDP2308
These controller ICs are completely configurable to match your application.
Abhilash P
Hi Abhilash,
You have provide broad range of solution.
Kindly tell me a specific one. My referance one does not suitable with this design?
Abhilash_P
  Currently as mentioned in my previous response, we dont have a reference design for your application.
But we do have it in our PFC+LLC combo controllers. The link for this has been provided in my previous response.
Abhilash P
Abhilash_P
Abhilash P
