aqgoc_3920151
I am currently looking for a buck-boost battery charger IC for a battery backup system.  The system is DC powered that is supplying 5V/5A to a 5V power rail and a 3.3V power rail. The max power demand for the system is 5V/4.8A and 3.3V/2A.
The requirements for the buck-boost battery charger IC are:
  • Being able to boost off the battery 5/1.2A and 3.3V/2A as the power demand increases.
  • Charge the battery when the power supply increase is not needed
  • Provide power to the system when the 5V/5A power input is cutoff using the battery
  • Easily integrable into an existing design, so a reference design/ design advice is needed as well.
Thank you.
Yuva
250 replies posted 250 sign-ins 100 solutions authored
Unfortunately we don't have devices to meet your requirements.
Yuva.
Yuva
Yuva.
