Ashbin
5 questions asked 5 sign-ins Welcome!
While programming into the NVM of IR38363 controllers, we are getting the the error - "Please load the latest version of Config file for Manhattan SVID". Screenshot is attached. Kindly let us know what needs to be done.
Ashbin
Vishnu_Pulik
25 sign-ins 5 likes given First solution authored
Hi  Ashbin,
Can you please share the configuration file?
Vishnu P
Ashbin
Hi Vishnu,
The config file was already shared to you in the IFX Case IFX-240207-1226489. It cannot be shared here because .txt file type cannot be attached in this portal. See the error below. I request you to take it from the case itself.
Ashbin
Vishnu_Pulik
Hi Ashbin,
Thanks for sharing the config file.
Before loading into NVM, load the config file in IR PowIRCenter and save that config file as a new config file. Then flash it into NVM.
Vishnu P
Bes
