--> I want to know whether this MultiCAN SBC IC (TLE9278-3BQX V33) will support CAN2.0A(11-Bit Identifier) and CAN2.0B(29-Bit Identifier) or not?
(As per my requirement MCU shall communicate with other modules on the vehicle via CAN 2.0 according to ISO 11898-1. Both 2.0A (11-bit) and 2.0B (29-bit) should be supported)
Is there any Design documents available for this IC?
TLE9278-3BQX V33 - Infineon Technologies
Hi Karthick,
SBCs are not ASIL product, there are no functional safety document for them. Instead of SBC, you can use PMICs (e.g., TLF35584) for your application, which are ASIL qualified products as per ISO-26262 standard.
Regarding FIT data,
However, as your question is related to quality topic, I request you to create a case under the sales support track in the Mycases portal.
Each track on the Mycases portal has a short description of the kind of questions supported by them. Kindly go through the description and submit your questions in the respective track. PFA of the customer case portal document for your future reference
Kranthi
Hello @kkarthick ,
Thank you for posting your query on Infineon Community.
Yes MultiCAN SBC IC (TLE9278-3BQX V33) will support both CAN2.0A (11-Bit Identifier) and CAN2.0B (29-Bit Identifier). Please find the attached screenshot from the datasheet, for configuring IDE bit.
Kranthi
Hi Kranthi,
Thanks for your reply.
We are planning to use the SBC with Single CAN with Watchdog (TLE9461-3ES V33) for Vehicle Diagnostic CAN. We need to attain ASIL C grade Failsafe. Is there any Functional Safety report is available for this SBC (FMEA/FMEDA)?
We need FIT value for this Component.
Thanks & Regards,
Karthick K
Hi Karthick,
Regarding FIT data,
Kranthi
