Is there any way to use LDO POWER_GOOD_ON or LDO POWER_GOOD_OFF without inadvertently changing other registers – or are these Power Good settings off limits for the LDO?
Hello @Kush1490 ,
Thank you for contributing to the Infineon community.
You can use POWER_GOOD_ON and POWER_GOOD_OFF through the IR PowIRCenter GUI. Refer to the screenshots below.
POWER_GOOD_OFF
Kindly refer to item 1 of the Errata Datasheet where you will have to Configure NVM bits (Source registers) so that the affected registers have acceptable data.
Nishanth
Hello @Kush1490 ,
POWER_GOOD_OFF
Nishanth
Thank you, Nishanth
