IR38164 control with I2C / Register Map Documentation
jcyndari
Is there a register map for use with programming the IR38164 using I2C?
The PMBus commands do not appear to map directly to register map from what I can see trying to read back MFR information, and I would like to program this part using I2C.
James Cyndari
Nishanth
50 likes received 100 solutions authored 10 likes given
Hello @jcyndari ,
Thank you for contributing to the Infineon community.
The Register map document cannot be shared in the community.
Kindly create a case under Tech support in our Infineon Case Management tool to get the register map document.
Note: Customer must have a valid NDA with Infineon to provide the register map document of IR38164.
Nishanth
Nishanth
Hello @jcyndari ,
Nishanth
Thanks, I had done that in parallel, and received what was needed.
