Nov 24, 2022
03:12 AM
Nov 24, 2022
03:12 AM
Hello, we are long time users of ICE3PCS01G. When we selected this ic the maximum operating frequency was 250Khz, now the datasheet report only 100Khz. Can you please explain this change? We did not receive any advice about this change. We have a lot of board designed to work at 125Khz.
Thank you
Max
Labels
ispn:1029:1:0
l1:144:1:0
l2:1260:1:0
l3:284:1:0
- ICE3PCS01G
05:16 AM
Nov 24, 2022
05:16 AM
Sorry for the inconvenience.
Value in the datasheets is regularly cross-verified with test data.
In the datasheet, you can see the frequency setting resistor is also verified. The new data is more reliable than the previous.
GA
Nov 24, 2022
05:35 AM
Nov 24, 2022
05:35 AM
Thank you for your answer. My concern is if a little higher working frequency can cause problems (eg. R freq.=39KOhm instead of 43KOhm)
Max
