I am currently using ICE3PCS01G to design a circuit, the specifications are as follows: VIN_AC=85V~265V; Vout=312V; 300W; VCC=15V. At present, the test is not working properly. How do I analyze it when there is no voltage output at Vref? In addition, is there any document that can introduce how to calculate the resistance selection of the Vsense & Vovp circuit.
ispn:1029:1:0
l1:144:1:0
l2:1260:1:0
l3:284:1:0
Hi @Robert1 ,
Thank you for posting in the Infineon community.
Refer Application note " D e s i g n G u i d e f o r B o o s t T y p e C C M P F C w i t h
I C E3P C S x x" for calculation.
Vref is generating internally once IC gets input supply (Vcc). Kindly check Vcc voltage at IC terminals.
GA
Thank you for your reply.
I still can't get it to work and I think I might have to wonder if my IC is a bad one. I attach my circuit diagram, can you help to check if there are any mistakes that need to be modified?
The Schematic looks to be fine. Please verify the following:
- Check the connection for BOFO modification is required there.
- OVP resistor divider required to be designed for a higher output voltage.
if there is no voltage at VREF, replace the IC and check.
Thank you for your reply. After we bought a new IC and replaced it, the function was normal. (The BOFO pin you mentioned is currently connected to Vref to make the system work.
But I have two problems, the first problem is that my ICE3PCS01G will be damaged when I adjust the AC input voltage to <95V. The state of the IC after damage is that Vref=5V is normal after VCC is supplied, but VB_OK="LOW" & GATE has no output.
The second problem is. When I raised the voltage to 100V, I did a load test, and the load was 25W, and my MOSFET burned out. The above two phenomena do not have these problems when I input AC greater than 110V.
What is the problem that causes the IC to be damaged when the input voltage is low?
The follow-up experiment is as follows:
If according to the design of my circuit, VBOP=2.3V when AC input is ~100V, then I connect the VBOFO point directly to VREF=5V (to disable boost follower).When there is no load, it can be used under low voltage (AC input>86V) and the boost outputs is 312V . But when I adjust the AC input to 100V and output with 75Watt load, the MOSFET will burn out and the D-S breakdown will occur. What is the reason for this situation?
Check the MOSFET and inductor current to see if they are saturated.
The reason for the large current of the previous waveform is due to the error in the attenuation of the probe. The re-updated information is as follows:
At present, I first test the current waveform of the boost inductor when AC=110V, and the capture waveform is in three situations: no load, 33W, and 49W. Can you help to estimate whether it is reasonable? Can you guess the reason why the MOSFET will burn out when the AC voltage is low (85-100V) and there is load?
Also, do I need to adjust Rsens & Cicomp?
Sorry for the delayed response.
I checked the waveforms, looks like a compensation issue (the drain and current waveform are not stable).
Adjust the compensation.
GA
