SEONGHUNPARK
Distributor - CHANGNAM
10 sign-ins First question asked 5 sign-ins
I wil not use TLE9255W's WAKE (PIN 9), the pin is already N.C (not to connect GND) so , I want to disable the LWU funtion with Register just in case. is it ok that LWU_NEG, LWU_POS are set "0" for disable LWU function with register ? or is there another setting for disable only LWU register ?
Albab_A
5 likes given 50 solutions authored 100 replies posted
Do you want to disable all wake-up source for this CAN Tx? What is the status of your SWK_EN bit?
Yes, you can disable LWU by disabling both LWU_NEG, LWU_POS.
Albab
Albab_A
Albab
SEONGHUNPARK
I want to disable only LWU with register. your answer is helpful for me.
Thanks!
