Power Management ICs Forum Discussions
Tanvi
Hey,
Id current is 400A . I want to use it for automotive traction inverter where requirement is 1000A current . Can I use this module ?
Thanks in advance.
Tanvi
Pablo_EG
Moderator 250 sign-ins 250 replies posted 25 likes received
Hello Tanvi,
Thank you for posting on the Infineon Community.
Unfortunately, FS03MR12A6MA1B cannot give more than 400A continuously and 800A pulsed as seen in Table 3 of the datasheet:
The closest rated module you could consider is FS950R08A6P2LB.
This is a 950A Id IGBT module, however, the blocking voltage is only 750V (compared to the 1200V of SiC).
Pablo
Pablo_EG
Hello Tanvi,
Pablo
