MS_19060803
Distributor - TED (Japan)
25 likes received 25 solutions authored 10 likes given
Hi all,
The user guide states below that the FOD function can be disabled.
The GUI they are using does not have a tab to disable FOD function as shown below.
Could you please tell me why the FOD function is not displayed?
The version they used is:
GUI: 1.2
Firmware: 1.0.1.221
LoadWRM483265-10F5-12V-G(TDK)
https://product.tdk.com/en/search/wireless-charge/wireless-charge/rx-coil-module/info?part_no=WRM483...
MS
Kanahaiya_K
50 likes received 100 solutions authored 10 likes given
Hi @MS_19060803 ,
To enable the "Qi FOD Configuration " tab please follow the below mentioned steps
1. Open the wireless charging configuration utility.
2. Go to the Tools section and click on options.
3. Check the "Enable advanced configuration parameters "
4. Save it and close the tab.
5. Reopen the wireless charging configuration utility then you can see the "Qi FOD Configuration"
Feel free to contact us for any further queries.
Kanahaiya
Kanahaiya_K
Hi @MS_19060803 ,
To disable the FOD function ,please follow the steps as mentioned below
1.Go to the "Qi FOD Configuration tab" and click on the "FOD Q Factor".
2.In the parameter selection tab ,Select "No" for the Q factor and Resonance frequency Enable .
3.Move to the "FOD Power loss" tab .
4..In the parameter selection tab ,Select "Disable" for the Enable power loss FOD.
5.Save the current configuration .
6. Click on configure device ,select the appropriate path and click on the" Program" to flash it.
Kanahaiya
MS_19060803
Hi Kanahaiya-san,
Thank you for the explanation of the procedure.
But the GUI our customer use doesn't show the Qi FOD Configuration tab.
Could you please tell me why the Qi FOD Configuration tab is not displayed on the screen?
MS
Kanahaiya_K
Hi @MS_19060803 ,
Kanahaiya
MS_19060803
Hi Kanahaiya-san,
Thank you for your support.
MS
