ataberkdlkl
hello, I'm using ISO1I811TXUMA1. Does this IC need an isolated supply or a mains supply to supply it? If an isolated supply is required, how can we provide it?
Sodum
50 replies posted 10 likes received 5 likes given
Thank You for posting your query in the Infineon community.
I hope your query is regarding supply isolation between input & output side of the IC.
Yes, input & output power supplies to the IC should be isolated, please refer the below link for more details,
https://www.infineon.com/dgdl/Infineon-Application_note_ISOFACE_safety_limits_for_ISO1I8xx-ICs-AN-v0...
Please feel free to contact for any further queries.
Premsagar S
Sodum
Premsagar S
so is there a way to supply the ic  it without an isolated supply?
Sodum
The primary application of ISO1I811TXUMA1 is to provide isolation between input & output. If we use common power supply without isolation, then the galvanic isolation provided by chip would be broken.
Please share information about your application for better understanding.
Premsagar S
