Can I get thermal resistance parameters, Rjc, Rjb and Ψjt, Ψjb and Tc for PN: TLE9255WSK?
DexterWeng
Distributor - Weikeng(GC)
10 questions asked First reply posted 10 sign-ins
Hi, could someone share thermal resistance parameters of TLE9255WSK as below with me?
Rjc (oC/W)
Rjb (oC/W)
Rja (oC/W)
Ψjt(oCW)
Ψjb(oC/W)
Tc Spec. (oC)
Tj Spec.(oC)
130
150
Thank you.
Albab_A
5 likes given 50 solutions authored 100 replies posted
You can get the thermal resistance parameter details from the datasheet which is described in the below image. For additional parameters, can you tell me the details for your required application so that I can check from the internal portal?
Albab
Albab_A
Albab
