Ong_MC
Distributor - Macnica (ASEAN)
25 sign-ins 10 questions asked First solution authored
COuld i check with you, which will be the best pin-to-pin alternative part from Infineon CAN transceivers product portfolio to replace Competitor part: LTC2875IS8#PBF (ADI) 8-Lead SOIC
Ong_MC
Hi @Roy_Liu, how about TLE9350VSJ? As P2P DSO-8 package is needed
Roy_Liu
First comment on KBA 10 questions asked First comment on blog
Hi Ong_MC,
My knowledge to CAN transceiver is limited 😁 but I feel mostly no pin-to-pin alternative, if I can still make some suggestion, will be go to the https://www.infineon.com/cms/en/product/transceivers/automotive-transceiver/automotive-can-transceiv... and figure out the most fit for your requirement, even you can download the list in excel and compare the features.
Roy Liu
