Mac_Kurosawa
Distributor - Macnica (Japan)
10 solutions authored 5 solutions authored 10 replies posted
Does the Infineon TLE935xB series comply with the following items?
  • CiA-601-4
  • Passed C&S group GmbH IOP test
Also, for the TLE937x series, although CiA-601-4 compliance is mentioned in the datasheet, has it passed the C&S group GmbH IOP test?
Albab_A
5 likes given 50 solutions authored 100 replies posted
Hello Mac_Kurosawa-san,
Thanks for your response.
CiA-601-4 is a standard for Signal Improvement Capability (SIC). TLE935xBx are not SIC transceivers but TLE9371x are, so TLE9371x comply with it.
C&S is a test house where IOPT test is carried out. TLE9371x has passed IOPT test. For TLE935xBx, the report from TLE935x can be used as the changes are not impacted by C&S test. So, yes TLE935xBx has passed IOPT test.
Albab
Albab_A
Do you want the compliance test results for both tests for TLE937x device also?
Can you please mention your application here?
Best Regards
Albab
Mac_Kurosawa
Hello Albab
Thank you for your reply.
The app is Shift by wire switch for HONDA.
Is there any other information you need?
Mac_Kurosawa
Albab_A
Albab
