Power Management ICs
saran
I am using BTN8982TA IC. In that IC, i am getting voltage as 1.93 in IS pin, and i am using Rs  as 3.6K.
How to calculate IL load current by using these values?
How to find the dkilis value?
Abhilash_P
Moderator 250 replies posted 250 sign-ins 100 solutions authored
   We can calculate il and dkilis as follows,
ils = Vis/Ris  = 1.93/3.6x10^3 = 0.5361 x 10^-3 = 0.5361mA.
dkilis = 1/ils = 1865.3236
Load current = il = dkilis * ( ils - isoffset)
   = 0.6828 A
Abhilash P
Abhilash_P
   = 0.6828 A
Abhilash P
saran
HI Abilash,
               Thanks for your reply..
              what's the value of is-offset?.. So that we can calculate the load current.
Thanksyou.
Abhilash_P
   Ioffset is 170uA.
Please refer the datasheet.
Abhilash P
