About the Wireless Charging Configuration Utility
MS_19060803
Level 6
Level 6
Distributor - TED (Japan)
25 likes received 25 solutions authored 10 likes given
Hi all,
They are evaluating REFWLCTX15WC1.
Then, I have a question.
Is it possible to fix the transmission power at an arbitrary value by setting the parameter of the Wireless Charging Configuration Utility?
REFWLCTX15WC1を評価をしています。
そこで質問があります。
Wireless Charging Configuration Utilityのパラメータ設定で、送信電力を任意の値に固定することは可能でしょうか?
MS
Kanahaiya_K
50 likes received 100 solutions authored 10 likes given
Hi @MS_19060803 ,
We appreciate your participation in the Infineon community.
Yes, it is possible to fix the transmission power with the help of configuration utility.
After reading the device by the configuration tool, click to the section as mentioned.
WLCx configuration->Wireless charger configuration->coils->operation
Change the EPP Potential Power & Guaranteed potential power as per the requirement.
After that save the configuration and flash it to the device.
Make sure that the value considered for the transmission will be the 0.5 times of the value entered.
Please find the attached image for your reference.
Kanahaiya
Kanahaiya_K
Hi @MS_19060803 ,
Kanahaiya
MS_19060803
Level 6
Level 6
Hi Kanahaiya-san,
Thank you for your prompt response.
MS
