MS_19060803
Distributor - TED (Japan)
25 likes received 25 solutions authored 10 likes given
Hi all,
They are evaluating REFWLCTX15WC1 by connecting Tera Term.
Then, I have questions.
Could you please tell me the meaning of the following parameters?
PLOSS_THRES = 325mW
PLOSS = -152mW
PTx_calib = 3175mW
Threshold = 326mW
DIE TEMP
REFWLCTX15WC1Tera Termを接続して評価をしています。
そこで質問があります。
下記パラメータの意味をご教示ねがいますか。
PLOSS_THRES = 325mW
PLOSS = -152mW
PTx_calib = 3175 mW
Threshold = 326 mW
DIE TEMP
MS
Ajeethkumar_P
50 likes received 500 replies posted 100 solutions authored
Please find the definitions below:
PTx_calib - Calibrated transmitter power(See equation 6 in AN234970)
NTC TEMP = Temperature sensor value in °C(External NTC temperature sensor)
DIE_TEMP = Temperature sensor value in °C(We have a Temperature sensor in the Die)
PLOSS_THRES - FO detection Power loss Threshold value set in the utility
Threshold - Corrected Threshold based on losses for that particular receiver
PLOSS - Actual power loss calculated
Ajeeth
Ajeethkumar_P
Ajeeth
MS_19060803
Hi Ajeeth-san,
Thank you for your prompt response.
Please let me know about the parameters below.
Threshold = 326mW
DIE TEMP = 28
MS
Ajeeth
MS_19060803
Hi Ajeeth-san,
Thank you for your detailed explanation.
MS
