Power Management ICs Forum Discussions
WEN-YUNG
First like given 5 replies posted 25 sign-ins
Hello IFXer,
I would like to know what is the k factor in paper?  and in chapter 4(page 23), could you help us to share the  TLVR Simetrix open-loop simulate file? thanks!
Sodum
50 replies posted 10 likes received 5 likes given
Hello @WEN-YUNG ,
Thank you for posting your query on Infineon Community.
Here "k" is the coefficient of coupling for the TLVR transformers.
The open loop TLVR simulation file is not open for public use and will only be shared with the customer with NDA. So, I would request to raise a case in Infineon Case Management system. Please find the below link to raise the case,
https://mycases.infineon.com/
Premsagar S
Sodum
Hello @WEN-YUNG ,
Premsagar S
WEN-YUNG
Dear Sir,
Thank you for  replied and may I know the coefficient of coupling for TLVR, normally has recommended value?
Sodum
Hello @WEN-YUNG ,
The coefficient of coupling ideally equals 1, but the typical value consideration would be 0.98.
Premsagar S
