- Email to a Friend
see one equation in th document AN_2011_PL12_2012_221647_Multiphase Buck Converter with TLVR Output Filter,at page 8,i suppose The formula vin-vout should be used in parentheses,(Vin-Vout),please help to comfirm
- Email to a Friend
Hi taoli,
Thanks for using Infineon Community.
It seems to me that this formula is without problems. In a Buck circuit D = Vout/Vin, then D*Vin is only comparable with Vout. Could you derive the formula at the beginning?
If you still have questions, please continue to use Community.
Steven
- Email to a Friend
Hi taoli,
Steven
