Hey!
We are developing a Li-Ion battery charger for a 48V pack. I came across a document in your website with similar specifications to ours. I want to know if there are any development boards available for sale in India relating to it. If not, can you provide hardware and software support if we are designing the system based on this document.
Hello @cw2611 ,
Please ignore my previous suggestion if you are looking for CC & CV modes of operation. You can check out other battery charging solutions available under below link.
Also, we will be happy to support your queries related to the design.
And in case if you are using it for commercial purposes, I would recommend you to contact Infineon's local FAE to check every part of the schematic to meet your design requirements or to get the source code for your design and to support the subsequent design work.
Meghana R
Meghana R
Hello @cw2611 ,
There is evaluation board available for the same design
Unfortunately it is currently unavailable. As an alternate, you can also consider combination of below evaluation boards to achieve the same functionality.
AC- DC PFC Converter : https://www.infineon.com/cms/en/product/evaluation-boards/eval_2k4w_act_brd_s7/
DC - DC Converter: https://www.infineon.com/cms/en/product/evaluation-boards/eval_2kw_zvs_fb_cfd7/
Please have a look. You can order these boards directly from Infineon or any distributor websites.
Meanwhile kindly share us your application specification. We will be able to recommend an appropriate solution based on that.
Meghana R
Thanks @Meghana !
The boards you have provided seems like for SMPS application. We require to charge a 48V / 80Ah battery pack using CC/CV method.
We want to develop the board in reference with the schematics provided in the document. Will you provide hardware and software verification support for the same?
Hello @cw2611 ,
Meghana R
Meghana R
Thanks @Meghana !
How can I contact the Field Application Engineer in India? We are based in Chennai, Tamil Nadu.
Hello @cw2611 ,
You can contact your nearest Infineon sales office which you can find in below link.
https://www.infineon.com/cms/en/about-infineon/company/find-a-location/
Or, you can use our direct channel, to submit your request.
Hope this helps.
Meghana R
