ajin
25 sign-ins First solution authored 10 sign-ins
I tested the code of 3.3KW semi bridgeless dual boost PFCCapture.PNG. In that code the PI values are calculated with respect to mean Power for current control loop (inner loop). I have doubt about power calculation. Can you explain the way they are calculating the Power. I also didn't get how they got ZK(Q0.15) = 3Hz/1KHz x 2^15 = 98.
Vinay
50 solutions authored 100 replies posted 250 sign-ins
Hi @ajin,
Good Day!
Thanks for posting your question in Infineon community.
Input power is calculated from Input voltage and input current.
P_In = U_in*I_in
Input power is filtered with a low pass filter with a filter factor of Zk. The value Zk is the filter factor of the input power to smoothen the ripples present in the calculation of actual input power.
Filter factor Zk = (To/T) = (3/1000)
Where T is the Time constant of the signal and To is the filtered sample time
Here time constant is 0.33 sec and filter sample time is 1 msec
Generic model of Low pass filter
y(n) = (x(n)-y(n-1))*Zk + y(n-1)
Where x(n) is the input to the low pass filter, y(n) is the filtered output and Zk is the filter factor.
Please refer defines.h header file for ADC conversion. Input voltage full scale is 938.88 V and Input current full scale is 34.09 A.
Thank you!
Vinay
Vinay
Hi @ajin,
Good Day!
P_In = U_in*I_in
Thank you!
Vinay
