geminikowui
now I need design the request as follow:
input: 12V-dc
output current: 10~100A /constant current
output volotage: 2~9V
can you introduct the design or the part?
Nishanth
100 solutions authored 10 likes given 100 replies posted
Hello @geminikowui ,
Currently, we do not have any part that can meet your requirements.
Nishanth
Nishanth
Can you be more specific about the output voltage and current requirement?
It would enable us to suggest you a suitable part.
Nishanth
Detailed design indicators are shown in the following table,tks.
Nishanth
Nishanth
geminikowui
thank you very much!
Can you give me a recommended circuit  About IR3846 Using a Constant Current Loop, if i only used one IR3846 how to used 30A constant current?
now i only know to connect FB(pin)  to change the output voltage, but don't know how to design the constant current output to used amplifier to FB(pin).
Nishanth
IR3846 is not designed to be used in a constant current loop. Hence it is not recommended to be used in the constant current loop.
Nishanth
