Power MOSFET
man
After to compare with the datasheet information. The parts have many different. Such as marking format, metal pad or mold location. Could you please help to confirm the parts is normal?
Abhilash_P
Moderator 250 replies posted 250 sign-ins 100 solutions authored
   It is recommended to follow the diagram given in the datasheet.
I have shared them in my previous responses.
Abhilash P
Abhilash_P
The part IRF3415STRLPBF is active part ( OPN ) of IRF3415 N-channel Power MOSFET.
The marking format of this part is as shown below,
Please do let me know if additional details regarding this part is required.
Abhilash P
man
Hello Abhilash,
I want to check the PN# is IRF3415S. If I chick the button on D2PAK. The result as below is PG-TO263-3-901 | D2PAK. It does not match your provide information. Please help to re-confirm
man
Is it normal if under the below photo?
Abhilash_P
  The package type of IRF3415SLPBF is D2PAK. The package outline is as shown below,
For low power applications, the same IC is available in through hole version i.e in TO-262 package. The package outline of this is as below,
IRF3415Pbf is available in TO-220AB.
I hope this explanation has answered your query.
Abhilash P
Abhilash_P
   The part number can be verified from the attached image in my previous response.
By clicking on D2PAK, you will get the package type of IRF3415.
Abhilash P
man
Hi Abhilash P,
Thanks your reply.
But I still have some problem on the parts. After compare with the D2PAK package outline and part marking. I find different in the top mark format, thermal pad and mold location. The parts of date code is 2119 and made from China. I have attached the parts photo in my previous respond. Could you please help to review?
Abhilash_P
   Can you please be a bit more specific on what exactly there is difference in the part marking?
Abhilash P
man
Hi Abhilash P,
1) The parts of dimple by mold gate location in upper, but the datasheet diagram show in lower
2)The shape of thermal pad is different if compare with datasheet diagram
3)The letter for KN12 without space, but 8024 with space.
Is it normal?  Or you can provide some  PCN to explain?
Please see the below photo. Thanks your help again.
Abhilash_P
Abhilash P
man
Hi Abhilash P,
Okay. Thanks your support.
