Hello Experts!!
I need your help, I have purchased the EVAL_3KW_2LLC_C7_20 Evaluation Board and initially I have Tested it got the output
later I have done some modifications in source and flashed and there is no output
but, when I received exclusive Information regarding Board there was an HEX file kept in separate folder
so I have flashed it, This was working with GUI communication perfectly I can set different output voltages 44v-58v
But normal operation its not working please help me for this I need a solution to operate it as it is when I have purchased.
regards,
Karthik
XMC
- EVAL_3KW_2LLC_C7_20
The 3kW Dual Phase LLC Demo Board is not intended to be used as a battery charger, so with the current hardware on the board, there is no way to implement CC and CV mode functionalities only by simple software adaptation. This can be implemented only with additional dedicated hardware according to the charging profile you would like to implement. In other words, the design of these additional functionalities has to be done by deciding on the kind of closed loop control and adding in the required hardware accordingly.
If there is no additional damage/change in the hardware, the board's normal operation will surely be restored by flashing in the code downloaded via product registration.
Sai
Sai
Hello @Bandarikarthik,
Can you please specify about what you are intending to do and how you are modifying the code and the inputs to the GUI ?
Kindly mention if any important measurements like voltages, currents are not ok as well and also any error log.
We'll look into that and get back to you.
Sai
Sai
Hello @psb , Thank you for responding
the board is working fine with GUI I can set different output voltage levels
and s I have received the Source Code from the Infineon when I purchased the product
While testing with out GUI if output current crossed 55A its out put is shutting down But I want to Act the CC mode where Output voltage should Decrease it meant for battery characteristics
But its not happening
Guide me I want to Implement the Control loop for CC mode what steps should I Take for implementing CC mode in this Module
regards
karthik
Sai
Sai
