So this is new... I tried adding an include file at the top of a source file and I can type "#include" but typing anything after that will result in an assertion. Strangely enough I can paste the line in without any problems. I assume this is the clang.dll bug. I added some blank lines around the end of the file and it appears to be okay now.
-Ray
Welcome in the forum, MyLord 😉
This bug is well known and has to do with the on-line checker named "Clang" which is active while you are typing.
Insert some blank lines at the end of your file and the assertion will go away.
Bob
Thnaks for the self diagnosis and feedback My Lord.
Regards, Dana.
